[技术帖(电子管类)] sunvalley 马7
sunvalley sv-pre1616d胆前级
那张实体搭棚图,有大图吗
ningokc 在 2019-11-8 11:26 说:
有非常详细的组装布骤,下班整理下发您信箱去
ningokc 在 2019-11-8 12:52 说:
还是把图已发给大家看吧,在审核中
Sunvalley SV-Pre1616D 115/230 version (point to point pre-amp project)
Made in Japan (Nagoya)
AVAILABLE now $795.00
- 12 AX 7 JJ ECC 82/12 AU 7
- 12 AX 7 GD 12 AU 7
- Mullard CV 4003/12 AU 7 (3 matched) SOVTEK 5 AR 4
You can use the following combination
① 12 AX 7 - 12 AX 7 - 12 AX 7 (Sharp and high contrast)
* Standard combination (SV - 722 Marantz type and same circuit)
② 12 AX 7 - 12 AX 7 - 12 AU 7 (Skeletal feeling and entity feeling of medium low range)
* SV - 722 Mckin type sound image Reproduced
③ 12 AU 7 - 12 AU 7 - 12 AU 7 (round and resonate rich)
※ Featuring a rich overtone feeling of the SV - 310 series
Input: 4 lines [Input 4 can be changed to USB input (option)]
Input Volume: Yes
frequency response: 15 Hz ~ 70 kHz (-3 dB)
gain: 15 dB
size: 250W, 225D, 135H (mm ) ※ including protrusions
weight: 3.6 kg
ningokc 在 2019-11-8 19:09 说:
图片怎么给审核没了?都是大图
只能一副副上了。东西方对美味追求一致但有区别,东方人更重饮食口味品质,欧美人更重视听感的品质的提升,都是美的追求
ningokc 在 2019-11-9 10:51 说:
蛤蟆神功第一式,上个图真难,又不行了,明天再补上
得带老花镜了,但绝不是烂尾,上图喽未完待续
NINGOKC的要頂、NINGOKC的要頂、NINGOKC的要頂!!!~:~
在美国兴致勃勃地制作淘宝散件也是人间一大快事
