[技术帖(其他)] 求ALTEC604同轴单元用的Big Red箱体图纸
据说能把604的素质发挥的更好
只有一个外观尺寸,板厚6分,宽23寸,高29寸,深18寸,低音反射式设计
Altec  620 箱体
Altec - AN-11-Construction-Plans-for-Low-Frequency-Enclosures-L-Reso_页面_07.png (942.78 KB)
Altec BR.jpg (32.01 KB)
其實就是612箱体,單元是8G,但內部分頻才是重點
看看逸品館,專營新淨易手古典器材
http://www.diybuy.net/forum-461-1.html
看看逸品館,專營新淨易手古典器材
分頻電路圖
xover.pdf (43.45 KB)
看看逸品館,專營新淨易手古典器材
為什麼說分頻器是重點,因為外表平平無奇的分頻器,但內部線圈是少見的高頻蜂房線圈斜線繞法,自製較麻煩
ffm 在 2025-4-16 10:42 说:
这种就是常见的补衣服用线棒的绕法,得找裁缝师傅做
看看逸品館,專營新淨易手古典器材
EL34 发表于 2025-1-31 11:08
网络资料:
The size of th cabinet s 30"x23"18",cabinets are only 5.6 cu ft and the actual speaker chamber is only 4.5 cu ft. The bottom 5" is a port that goes to the back of the cabinet with a 5.5" opening to the speaker chamber, a 17" x 4" opening on the baffle.
回复 6# 澳門客
网络资料转发:
So I finally came up with a pair of Audiotechniques Inc. Mastering Labs crossovers.
Based on a few measurements and tracing my way through the units I can say pretty certainly the schematic that has been floating around the internet is wrong, very wrong.
I've got to dig into it a bit further, but so far L1 is a tapped inductor, but only uses the tapped portion, L2 is much greater value, C1 is smaller, R3 is non-existent, ATT1 is a greater value than listed, L4 is a tapped inductor but the tap is not connected, and L5 is much smaller than listed...
I'm going to fully dig into these and come up with a correct schematic.
"You can't believe everything you read on the internet" – Abraham Lincoln
Corrected M_L_604_Xover.jpg (92.59 KB)
国外也这样玩?
