[出售] 出一对完美的 TAD 1602钴---- 加图 加图 加图 加图 加图 加图
货物名称 出TAD 1602钴磁 99成新 05年原厂买进 曾做过消音室配对 无任何损伤
运输方式及运费 自理
卖家联系方式 13691426666
三包或保修期
物品缺陷及改动
价格 12000
货物数量 2
最低谐振21HZ Q0.23 97.5DB 无氧铜音圈 钴磁 泡沫边 非常适合号角 等效容积519升 速度要比1601块很多 因为纸盆要比1601轻很多,低音号角专用, 很新 时间长了就是外面盆架有点土 擦一擦就干净。 因为工作 暂时没时间玩了,难得的消音室配对,同期挨号,原来买进加配对加保险15000多呢。
Because of its low frequency response of 21Hz, the TL-1602 low-frequency loudspeaker is especially suitable for a system with emphasis on rich lows.
由于其21Hz低频响应的TL - 1602低频扬声器,特别适用于具有丰富的低点重点制度。
Featuring a well-designed cone diaphragm, the unit may be used for studio monitoring as is, or loaded with a horn in a sound reinforcement system.
具有良好的锥形振膜设计,该装置可用于监测的工作室,或在一个扩声系统喇叭加载。
VOICE COIL The voice coil is relatively short so that it remains within the magnetic gap even during peak excursions.
音圈线圈的声音相对较短,以便它在磁场的差距仍然是在繁忙游览。
But its long travel distance results in reduced distortion at high input levels.
但它在降低长途跋涉的距离结果失真在高投入的水平。
The coil we use is ribbon wire, wound edgewise on a bobbin with heat-resistant adhesive.
我们使用的线圈是带状线,伤口上与耐热胶粘剂筒管曲方。
Making more effective use of the flux, it assures increased acoustic conversion efficiency and safe operation even when faced with 300 watts max.
更有效地焊剂的使用,确保提高声转换效率和安全运行,即使有300瓦的最大困难。
input.
输入。
MAGNETIC CIRCUIT A heavy (3 lbs. 10 oz./1.65kg) alnico ring magnet of carefully selected materials and pole configuration produce an extremely high flux density of 11,800G.
磁路沉重(3磅。10 oz./1.65kg)精心挑选的铝合金材料和极点配置的环形磁铁产生极高的11,800磁通密度湾
Lightweight moving parts and the long-travel voice coil together result in a sensitivity of 97dB/W (1m), and excellent specification for a unit of this size.
轻量运动部件和长期旅行音圈,一并结果灵敏度为97dB /瓦(1分),优良的规范这样大小的单位。
DIAPHRAGM A wide piston motion range is assured thanks to a cone made of highly rigid carbon fiber.
膜片宽活塞运动范围是有保证的高刚性碳纤维制成的圆锥感谢。
The diaphragm is covered with a special TAD-developed damping agent to reduce cone breakup and distortion.
膜片上覆盖着一个特殊的泰特开发的阻尼剂,以减少圆锥破碎和变形。
The polyurethane surround is structurally symmetrical and highly compliant to further reduce distortion.
聚氨酯环绕的结构对称,高度兼容,以进一步减少失真。
The frequency response is 21Hz for accurate reproduction of ultra-low frequencies.
的频率响应准确再现超低频率21Hz。
HOUSING A rugged, low-resonance frame of diecast aluminum alloy capably supports the heavy magnetic structure and the moving parts.
住房 ,坚固耐用,低压铸铝合金框架才华共振支持重磁结构和运动部件。
It does its part in keeping coloration to a minimum.
它在保持其部分着色到最低限度
买、买-----买---------------------------------------------------------
---------------不起。
帮顶,事业更重要[attach]427109[/attach]
岁月尘封住不尽的往昔,影像却可为我们打开一扇记忆的天窗
老大有没有一套4只啊?
没有图?
李松岭1  ?听说这是个老烧友?
写错了 是05年购进 呵呵
请上图看能不能配我的号角箱
想进来看看好喇叭。。结果没图
